Hi
I've just bought new water pump gaskets for my 65, which I thought had a 71 302 but the engine side one is totally different, could someone please help me identify it.
Have done a little research and can state it's got a pass side lower outlet, a 3 bolt crank pulley, the pump is cast iron with a number ph355 on it. Here's a pic of my pump.
Mike
You may have a 1971 engine but an earlier model pump. Ford switched to a drivers side outlet in 1969 if I remember correctly. I would look for a pump gasket set from 1966-68. 1965 had two different pumps is the reason I am suggesting 66 instead, that was you don't get the aluminum pump gasket by accident.
There should be no difference in the gasket. Got a pix of the back side with the gasket laying on it?
