FE
Gaskets from standard Fel-Pro set.
What (if any) sealant should I use with the gasket at Fuel Pump, and Oil Filter Adapter?
I hate leaks if it makes a difference.
Thanks.
I just used regular RTV for the fuel pump gasket. What oil adapter? Are you putting on a remote filter or somethin?
oil filter adapter hangs off side of block, two bolts hold it on block, oil filter screws up in to it.
FE engine.
