Front and rear, can someone give me the scoop on how they are attached and how to remove them?
I think that they have the same layout as the 70 I had four openings on the uner side of the car both drivers side and pass they have rubber covers over them remover the covers and with I think a 1/2 deep socket they should come out the rear upper you need to remove the bottom first then the two bolts that hold it, the top section has two sections that clip into a section of the seat backing.
make sure the buckets are folded down or they will fall back and might hit something or tear something
