I purchased a 390 mach 1 that has a 428 cj installed. It came with a fiberglass hood and template, we cut out hole in hood and installed on car. When we went to install the shaker on the engine and the hood wont close because the shaker sits up to high. Whoever assembled this package put a eldenbrock performer rpm intake which sits to high. Does anybody know what my options are, really prefer to keep intake but dont know if i can. Shaker is an aftermarket so I could cut it at base, or would adjustable motor mounts work please any help would be appreciated. thanks. Devan Dotson
Is your intake a performer 390 edelbrock? If so that intake should be dead nuts to a stock height intake. I would say your issues are in the fiberglass hood or the shaker. My guess is your shaker base is for a 302 or a 351 car. Post some pictures of your base.
Thats your problem. The RPM intake is too high....
Remember that shaker bases were different heights depending on the engine so that the shaker would sit at the same height in the hole on all cars.
Might have some room to adjust with a different base.
The performer RPM will sit back to the fire wall too far. I'm not sure about height because the RMP will not even fit in the hole in the hood.
