Has anyone here ever replaced the 3 studs in the shaker base that holds the midplate in place? How are these attached? I tried heating one, thinking maybe they were soldered in place but it didn't budge. Thanks for any tips anyone might be able to give.
Dennis
Never took them off but I do know they are spot welded on.If you look close at them you will see 2 dimples on each one. That is were the spot weld is. You will have to break those loose and they should come off.
Sorry I should have asked Big Block or Small Block. They are different. The reply I gave was for a big block.
