I won a special award
Does the top on a shaker scoop mount directly to the intermediate plate? Or is there another part that goes in between the two? I'm not referring to the hood seal gasket either.
Shaker
There is a bracket between the scoop itself and the mid-plate. It screws in to the scoop with about 6 or 8 small screws and allows you to connect it to the midplate. One large screw in the front middle and one in each rear corner. This is also where the gasket is sandwiched between the two.
You can see it mounted on this eBay auction. not mine.
260759746491
260759746491
Ok, I see it now in that ebay add. Are those reproduced? Any idea on what those brackets cost?
