Anyone who has done this, which kit would you recommend? (i want the simplest install possible). I want a very mild shift kit, since my engine is stock with stock gears.
i saw the B&M but they have a kit for 67-69 C4's and 70-82, beats me what mine is, whats the difference? (my engine is probably 1970 not sure on the tranny). My car is a 67
67 C4, (1971 302 block), daily driver.
Try here for a kit from TransGo
You can also try your local trans rebuilder; they may have access to a generic kit that is less expensive...I used one called a TransCo and it cost 9.95 back in 1994....
Pat
Sometimes you get lucky and the id tag is still on the tranny. It's like 2" long. Post it if you got it. I'm sure someone can ID it. I agree with your thinking about not modifying it to the "full blown" state. For daily driving you might be better off with the "tow" modification.
When my '67 had the C4 I put in one of those $20 B&M shift kits. There was an improvement, but the tranny lost 1st gear a couple months later. I don't think the shift kit had anything to do with it, the tranny was self-destructing before I put the kit in. There were 2 stages you could install the kit as. I chose the towing stage or something like that (the lesser of the 2).
It was a simple install (drop the pan - messy - take out the valve body, move some things around, put in the new plate, bolt it back up, fluid). Just be sure to read the instructions. I did it when it was 20 degrees outside, but I was in my garage. Still cold though.
Evan
67-5.0L
http://eyrules.com/mustang.html
I inquired about shift kits at a recommended re-builder. The guy I talked to seemed to know a sick amount about C-4 trannys so I thought his advice was likely dependable. He told me to stay away from the B&M shift kits (everyone has an opinion, I bet) and said that if I wanted to "improve" shift quality, the Trans-go was the way to go.
It was pretty easy to install (though i went and dropped the damned shuttle balls into my drain pan when I was draining the valve body....rrrrggghhh) but the shifts are MUCH crisper now and it's a blast to drive.
My only complaint was that Trans-go accidentally included the wrong instructions for the year of my transmission but they were great about faxing me the correct ones right away.
I'm planning on installing a pro-matic 2 shifter soon.
'69 coupe in the making
