1 - 9 of 9 Posts
I am installing a new aluminum heater core in my 65. Not having used aluminum heaters before, I don't know if there is a correct procedure to install the hoses to reduce corrosion.
The hose is rubber so there should be no particular corrosion between it and any metal, aluminum or otherwise. That said, I see no downside of a little silicone based grease.
I've read the aluminum cores are junk and to spend the money on brass/copper so thats what I did on my 64.
If your concerned about corrosion, do two things: 1) get a radiator cap with a sacrificial anode and 2) be sure the radiator has a really good ground (I'd add a grounding wire).
Personally I like to put a little grease on the inside of any hoses just to try and make them easier to take off next time. I don't know that it helps with any corrosion, but it does seem to make them a little less likely to get stuck in place.
I would use spit inside the hose for easy install. Never silicon sealant as it is slicker than snot if dried then cracked apart, then re-used.
68 Mustang Coupe
Something water based. Dish soap works beautifully.
1 - 9 of 9 Posts
