Can someone tell me if this is an indication of a bad starter. When I turn the key, the starter spins but the engine is definitely not turning over. I just get a fast spinning sound from the starter. The car is used daily and was just started and running about 10 minutes earlier. Its a 67 with a 289, and I guess I can pull the starter and take it in to get tested, but I just want to make sure before I start scraping my knuckles.
sounds to me like either the bendix of the starter is not engaging or you have a bad spot on the ring gear.. first I would try it again,, if still the same,, I would try to turn the motor over either with a breaker bar on the crank pulley or if it is a manual transmission,, push it a little and pop the clutch,, thus turning the engine over a little,, then try to start again,, if still the same result,, then pull starter and check bendix/gear.. hope this helps...
Either the gear on the starter is not engaging the flywheel/flexplate or is stripped of the teeth on the gear. Worst case, your flywheel/flexplate has a spot where the teeth are gone. I would bet the starter gear is just not engaging. Take it off and have it tested at your local auto parts store.
Discussion Starter · #4 ·
Thanks for the suggestions guys. If it ends up being stripped gears on the starter, do I just replace the starter with a rebuilt one? Or can just the stripped gear be replaced?
Take the starter out and have it checked. While its out take a close look at the teeth on the flexplate/ring gear. Look for worn or chipped teeth.
Discussion Starter · #6 ·
If I end up having to replace the starter, should I hang on to the bad one in case it's the original starter? I have no idea if it is indeed the original. Any benefit to keeping it? If so, how can you tell if its original equipment?
You will most likely need to exchange your old starter or pay the core charge. Unless you are building a concours car I wouldnt worry about keeping the starter. Most likely it has been changed out anyways. HTH
Recently on a different vehicle, I had the wining and no engaging of the starter. The bullnose had cracked on the front of the starter. Look for cracks also.
Kerry
