·Guest
I have a '68 J code 302. Rather healthy (350+ flywheel HP). It currently has the original dual vacume dist. with a Petronics conversion. I run 34 degrees total advance. The dist. hoses are plumbed properly. I have to use 24 degrees initial timing because the dist. only advances 10 degrees. What is wrong with my distributor? I was looking thru a Mustangs Unlimited catalog and it lists a single adnvance dist. for '65-'73 302. I show the car, and originallity (or the possibility) is important to me. Did any '68 and later 302 actually come from the factory with a single advance dist.?
Summit lists a high performance, blueprinted, adjustable single vacume advance dist.made by Accel for $99.
Has anybody had success with this? Can it pass for stock?
