1 - 2 of 2 Posts
I need a pair of 3 bolt rings that bolt on the 70 mustang disc brake dust shield .Again it is a plate with 3 holes for bolts and a larger center hole to fit over the spindle to hold the dust plate on. Must be rust free as not to fall apart when bead blasted. Also could use for( ONE SIDE ONLY) large nut,flat large washer , and tin nut (for cotter pin fit) that holds the rotor on for a 70 mustang. I have bearings
hi guy i have one of them that should fit your need asking 5 for it i should also have some nuts and thinkgs from a 70 drum brakes that should work on the spindle the nut the washer and the retainor another 5 for both sides and actual shipping. and i also have some decient dust shields bill
1 - 2 of 2 Posts
