couple of Q's
the starter flange measures 4 1/8 outer dia
the hole in the blocking plate is a smidge under 4 1/8 dia
what is the best way to enlarge
the blocking plate starter hole?
so the starter will fit?
also, how much torque to the Bell H to engine bolts?
iowa
If your starter is bigger than the hole, you have the wrong starter. Ford had two different sizes.
Smallblock starters will make ya crazy. 64-67 starters were the same regardless of transmission. All that goes out the window when people built these things from spare parts. Here's the listing from the catalog I keep handy:
G08159 641⁄2-67 260, 289, 302, manual with 157T flywheel, all C4 automatic, 68-73 289, 302, 351 with automatic trans Starter
G08161 68-73 289,302,351 manual trans with 164T flywheel Starter
