Mike's Transmission 'ULTIMATE VASCO C4 TRANSMISSION' with JW ULTRA-BELL bell-housing.
I know, i know, never say never. .. pardon the hyperbole ... just sayin' it's pretty damn stout.
From their site - - Top of the line C4 transmission built for extreme conditions. Each with the parts & technology it takes to survive with power adders such as nitrous or superchargers. Each transmission is specially modified for your application. This transmission features: ~ C4 transbrake valve body. ~ Vasco 26 spline input shaft. ~ Solid forward drum. ~ Six clutch pack in the forward & direct drums. ~ Six pinion front planetary. ~ Large diameter servos. ~ Rigid second gear band. ~ Teflon sealing rings. ~ Deep aluminum pan.
To complete the setup - ALSO - includes 2 converters, an 8" @ 5K and a more street-able 10" @ 3K; Turbo Action Cheetah SCS shifter; super trick Lokar transmission shifter cable; set of -8AN braided lines that go to and from a -your- trans cooler with an in-line billet temp sensor block,; and lastly a Pro-Comp Ultra-Lite trans temp gauge with mount. Condition - BRAND NEW - it was not raced. Maybe saw 8 hours of run time / neighborhood shake down runs before the project changed direction.
$4K + shipping (or local pickup in Hayward, CA 94545)
*** the JW ULTRA-BELL can be swapped with whatever set up you've got. The one installed adapts to a FE.
745474
745475
745476
745477
745478
Do you realize that you posted this in the "Want To Buy" forum, not the "Parts For Sale" forum?
Just some guy
You joined 9 years ago and are just now posting?
To sell stuff. ......OK.
Moving this thread to the drivetrain parts for sale section.
If you're offering local pickup you might want to put your location in your profile. And maybe double up by putting it in your ads too.
Reactions: guyoverfelt
thanks for moving the post in the correct area. appreciate that. apologies for posting in the wrong section. the location updates have been made.
yes. correct, I joined 9 years ago, and am posting top-shelf parts at really great prices. ?
