Hi folks,
I have a 1966 mustang with front brakes swapped to CSRP kit (manual).
Having a problem with brake lights which began a month ago: brake lights turn on only when the brake pedal is fully pressed -- probably the last 5-10% of the pedal travel. The brakes work just fine, only brake lights are affected.
Details:
Should I try to bend the switch panel to make it more sensitive?
Could I be missing some bushing required for proper work of the switch (some topics on forum say plastic bushing has to be removed)?
Is that something to do with CSRP's adjustable push rod?
Is there some specific way how the switch needs to be mounted to the push rod (I tried with white silicon bushing going under and over the right "shoulder" of the switch, it made no difference)
PS: brakes were replaced a year ago by reputable mechanic experienced in classic American cars, pedal seems to be properly adjusted (0.5 inch travel in top); the issue started only recently.
Details:
- Replaced the bulbs. Confirmed tail lights work as well as turning signals.
- Disconnected the connector from the brake switch and confirmed the wiring works fine: when I connect the contacts on the connector the brake lights turn on.
- Bought two brake switches.
- Confirmed the brake switches work
- Multimeter connected to the contacts + push the metal panel == connectivity
- Connected the brake switch to the wiring, pushed the panel -- lights came on
- Replaced the brake switch (tried both)
