1 - 10 of 10 Posts
I'm a big fan of my SoT front coilovers and am saving to do the rear end. Unfortunately this weekend I noticed that a serious wheelhop issue caused my drover rear exhaust mount to tear free from the subframe. Obviously, I could re-tack the hanger and ideally repair the subframe at the same time but it may be an opportunity to upgrade before the Spring. Where exactly do the frame mount reinforcements weld in? (tough to tell from the pictures on the website)
I'm sure Shaun will chime in soon, but I don't think they weld in at all (or don't have to be). Have you seen the install video?
Vendor
Sorry you had some wheel hop, the 3-Link will fix that! :wink:
Not exactly sure what frame mount reinforcements you are referring to?
Vendor
Ahh, I see now, thanks.
That connection is made by a 'U' shaped bracket that gets welded to a 6" x 6" plate we send you that in turn is welded to the frame rail/torque box.
This picture shows it better (also shows how it ties into our frame connectors):
Discussion Starter · #6 ·
That helps, thanks Shaun. But it brings up other questions:
1) Is this worthwhile on a primarily street car (meaning the frame rail mount vs the stock leaf location)
2) I already have the TCP subframe connectors welded in. Would I need to remove them to put that plate in?
Vendor
If you plan on mini-tubbing the car then do the frame rail mount, if not, put the trailing arm into the leaf spring hole.
2)I already have the TCP subframe connectors welded in. Would I need to remove them to put that plate in?
I haven't seen those installed in person in a while but I don't believe they occupy the same space.
Please let me know if you have any other questions.
This is probably a dumb question for which I believe I know the answer, but...
Do the 3 link mounts and the leaf spring perches on the axle occupy the same space? I only ask as I'm considering a floater, and I would like to run the trailing arms/traction bars, but I'm not ready to convert from leaf springs. I suspect they do...but I figured I'd ask :).
Thanks.
Vendor
Thanks.
Its going to be either or, you shouldn't use leaf springs with the 3-Link (if it was even possible to package it).
1 - 10 of 10 Posts
