After spending my lunch hour at work today mounting my new high performance puller fan to the radiator I bring it home to put in the 'stang. Here is where the problem lies. On the I-6 the water pump hub juts out from the block 4 1/2" and then the belt pulley which is dished out slides over and past the hub so that the belt will line up. Does anyone know if there is a water pump that will bolt up with a shorter hub distance. I have already mounted the fan and am sure it can't be returned. (not that I want to, as it really moves some air.) I am wondering if later model 200 or 250 6cyl's have a shorter shaft length. I need to gain about 1" clearance. The depth of the 16" fan I have is 3.39" and puts out 2360cfm, there is anothe 16" fan with a 2.05" depth but it only puts out 1378 cfm, will this be my only option? Thank you for your help.
Might try sending an e-mail to A&A automotive specialties (TRW) in L.A., the guys down there should be able to tell ya which pump will work...
2nd option is to pull your present pump, take it to a machine shop & let em modify it.
You might want to look at moving the radiator, seems Kent and some others had to do that....its another option, at least..
Move the radiator?! How did they do that?
re-welded the mounting tabs and moved the radiator further away from the motor, I believe. Go to Kents website, he might have pics...
