1 - 12 of 12 Posts
Ok , so after a lot of help on a different thread about gear ratios where I was not going to be happy with the close ratio top loader I was putting in to replace my 3 speed, I sold the close ratio and purchased a wide ratio with the hurst shifter and linkage, supposed to have been rebuilt and does look like it was , with the exception of the speedo drive gear has some smears on it like someone but the wrong driven gear in and rotated it. It has a black 7 tooth gear in it.
It is an RUG- BJ1 so according to the numbers it would be out of a 72 mustang 351CJ. I need now to get a new speedo cable and will replace the drive gear and get the correct driven gear. So I started looking at speedo cables and one listed for my car ( 71 mach1 ) says ( except 351 4V ) I can't understand what would be different about the cable but anyway if I am putting this message across so it makes sense, Any input on how to find the right cable and figuring out which gears I need would be appreciated. Thanks
Use the correct cable for the year of your car. The hole in the 4-speed trans was the same for all years. The 4-speed cable inserted on the right side, all others on the left side, so the 4-speed cable is much longer. Naturally, the 4-speed cable gear has a left twist, so don't try to use the 3-speed/auto trans gear, which has a right twist.
I am aware of the directional gears, I think thats what someone did to mar the gear in the trans, So I was looking at a sight a while back explaining how the correct gears are determined ( amount of teeth ) based on your axle ratio etc. And I think there is a range for each. I cannot find that sight now. I was a little confused at wether the different driven gears could work on the same drive gear for different applications, I think from memory I need to replace my black 7 tooth drive gear ( because it has damage) and then figure out which driven gear will work for what will probably end up being a 3.25 rear.
Yes, the driven gears can be driven by all the drive gears, they are not a tight mesh like axle gears.
Try this-
NPD has a speedo cable in the correct length for the 4 speed cars. It's a bit pricey, which I'm going to assume is it's a custom made cable for them.
Everyone else has consolidated the 66" and longer cables into a single 80" unit, which is a PITA to secure under the car.
1967 Mustang Hardtop
I used this calculator yesterday to order a replacement drive and driven gear.
Fortunately the black 7 tooth drive gear seems to be the one with the most workable combinations. You can find tire size calculators pretty easily.
True, at least for aftermarket. When the Barn still had a catalog, we would buy the 80" cables by the carton, then cut them down to the Ford specification size, re-crimping the speedometer end, and re-crimping the square drive end on the cable. Fairly simple job, but the darn tool is about $100, if you can find it. Just used it recently to make the cable for this-
760639
Beautiful Daughter,
I recently installed a black 7 tooth drive gear and a 17 tooth driven gear in the top loader for my 73 Mach. I am running 3:25 gear with 255-60-15 rear tires and my speedometer is accurate within a mile an hour, just saying.
Thanks, Jay
Discussion Starter #11
Beautiful Daughter,
Thanks, Jay
Thanks , Thats what I figured I needed with the use of the web sight supplied. I Already ordered the 17 tooth
Discussion Starter #12 (Edited)
I received the new black 7 tooth drive gear today and it has an extra notch where it fits on the shaft, the one I have removed has a halfway slot for a ball bearing to make it ride with the shaft and only allow it to go in the proper direction. The new one has a slot opposite that that goes all the way through. I am assuming that is for an optional way of holding it on instead of the c clip ?? and that with the c clip I will just install it like the original and just disregard that notch ????, I remember on the close ratio that I sold I could feel a round clip of some kind that this one doesn't have.
Never mind, I finally found the answer, I guess it was an optional way of fastening the gear, Thanks anyway.
1 - 12 of 12 Posts
