1 - 12 of 12 Posts
I replaced the Konis on my GT350 clone on Saturday, with Sport valved Bilsteins from Street or Track.
I was on the fence about getting the street or sport valving....as I get older (40) I’m starting to prefer a bit more comfort, and I didn’t want it to be too harsh.
I ended up going for the ‘Sport’ valving, and my concerns about harshness were totally unfounded. The car is actually just as comfortable as it was with the Konis on their softest setting. It’s not the slightest bit harsh.
Where the Bilsteins were really great was out in the mountain twisties yesterday. The car was much more controlled, and confidence inspiring as it soaks up high-speed bumps in a way that I almost couldn’t believe. This was probably the single best change I’ve ever made to this car.
One thing I used to deal with was my suspension bottoming out fairly frequently with my 540 lb/in springs, but it never bottomed out once with the Bilsteins. Adjusting the Konis never seemed to help this, because (I believe) they are only adjustable on rebound.
From the pics, you can also see I’m part-way through converting my car from an ‘R’ valance to stock sheetmetal and bumper. I love the way it works with the steel wheel.....hoping to paint the new panels this weekend.
Looks great! Good to hear someone coming from Konis also. I've been on the fence between Koni and Bilsteins so this was definitely helpful info. Did the Bilsteins change your stance at all?
Did you have to cut some coil in front and use lowering blocks in the rear for your stance? My 66 is pretty low also and I have the same issue with it occasionally bottoming out, even with 560lbf/in front coils and 4.5 leaf reverse eyes. Besides planning to change out my old KYB shocks, I've also plan to slowly rollerizing the suspension and/or remove rubber anywhere I can. So far I've only done the coil spring perches and strut rods but that was a noticeable change.
Your shocks should not determine your ride height. Their sole purpose is to modify the spring's rebound. If your current shocks are holding up the weight of your car, they're garbage. I suspect you're bottoming out because the KYBs aren't great at controlling rebound.
That said - I LOVE my Bilsteins. Money well spent IMHO.
I put on Bilstein sports last weekend and I am glad I went with the Sport and not Street. I was also looking for a nice ride v/s harsh but these sport versions are PERFECT, I actually am curious how the race versions feel. I too would have to be careful in some spots of bottoming out if I was going too fast through in intersection or "hump" in the road. That seems to be cured with the Bilsteins, I have about 100 miles on them and like them.
I have 620 1" lowering springs, 235-45-17's in the front and 245-45-17's rear.
Brent,
I agree with Sparky66, that shock absorbers should never influence ride height.
My leaf springs are 5-leaf Global West (L-10?) springs, which sit basically flat, right out of the box. My car has some thin, pinion angle wedges under the axle, which probably bring the car down another 3/8”.
The front springs are whatever Moog springs are used to produce the aftermarket 540 lb/in springs, and I just kept cutting them down until the lower arms were parallel with the ground, and the front sat appropriately compared to the rear.
Looks great, and Good to hear.. I’m looking to replace my shocks and have been a fan on Bilstiens in my truck. I also bottom out when the family is with me and was hoping the sport Bilstiens would help that. I know what my next purchase will be!
Same here. I was on the fence between the Street or the Sport version. In a knee jerk move I blurted out Sports to Shaun. No regrets, love them
Discussion Starter #10
was it just a shock swap? or did you change out any of the other parts?
It was just a shock swap.
The car already has:
-Export brace
-Monte Carlo bar
-Global West upper and lower arms
-Roller spring perches
-Boss 302 Trans-Am crossmember
-Roller Idler Arm
-Heim jointed, adjustable strut rods
So, I was just going from Konis to Bilsteins on this solid platform, and the difference was amazing.
-Export brace
-Monte Carlo bar
-Roller Idler Arm
Benny, you just described my suspension except I have the Opentracker delrin strut rods (same shocks). I have not chosen rear springs yet. Do you have the delrin rear spring bushings?
Look like I am on the right track with my choices and should be happy once my car is on the road.
Very nice looking car; your pics look like you were on MT Laguna (sunrise hwy)?
Discussion Starter #12
Yes, I have the Del-Alum bushings in my leaf springs. They were fairly difficult to install, but I’m glad I went with them. If you end up getting them, drop me a line, and I can pass along some lessons I learned during my installation.
I’m also running Bilstein rear shocks, which I installed about a month ago. Those weren’t as transformative as the fronts, but I do prefer them over the rear Konis I had.
You are pretty close on the location. I live in La Mesa, so I take Lyons Valley to Japatul Valley, so these pics are sort of in the foothills of Mt Laguna.
1 - 12 of 12 Posts
