Any ideas on spraying my headliner with vinyl dye without getting it on everything? I just ordered 2 cans of black satin vinyl die. My headliner is in good condition but its white where as the rest of the interior is black.
Thanks, Ron
I did the same to a coupe a few years back...white interior and I dyed it black. Take the pinch mouldings off and mask the windows just like you are spray painting. Paint the pinch mouldings separately and it will turn out a lot better. Just spray that stuff like it's regular paint.
Years ago I did the same thing, it worked great. I agree with Red66 as far as prep goes. Roll down the windows and use a couple old sheets to cover the seats, dash and doors. You don't have to cover everything at once, just move the sheets to the areas you are working.
Be sur to mask the front and back windows or else you will have overspray on them that is tough to get off. Don't ask me how I know. :eek:
I just did this myself. Like others have said, make sure you cover everything you don't want overspray on. I would suggest taking the seats out - you can do that in about 15 minutes and it will give you a lot more room to move.
The other suggestions I have are to wipe down the headliner with lacquer thinner before you spray (don't overdo it though). This will not only remove dirt & oils from the headliner, it will also soften it up a bit and let the dye penetrate a bit better. I chose to do half the headliner at a time, that way it stayed soft while I sprayed. The other thing is to just use lots of very light coats in opposite directions.
It should look great if you just take your time.
