1 - 12 of 12 Posts
Anyone know if there is a modern match for Springtime Yellow. I've made some marks in my paint and I'd like to get some touch up paint. Is there something close I can use? Both areas are not in highly visible areas so I'm not concerned about a perfect match.
Found this: Springtime Yellow
I don't know about your locale, but my local O'Reilly's will mix me up a "touch up bottle", about 2oz, for $15 or so.... an aerosol can of lacquer for around $25.
Thanks Bart. There's on O'Reilly's right near my office. I'll ask them.
O’Reilly’s sells paint?? I’ll have to check them out! Especially if they can do cans of lacquer. Thanks for the tip!
Rob
Not all O'R stores mix paint, maybe 10% or 20% of their stores do. If you want a can of "standard" paint your local store can have the closest store with paint mix it and send it to them. If you need a "custom" color you will have to go to the store that has paint.
Quite true. A good paint store can match what you have, even if it's "off" or faded.
You can also get original colors from paintscratch.com. But again, does not take into consideration fading.
They've got nearly 5,500 stores, so it's a relative rarity on the paint services.....
(these are the two most folks don't know about)--
Custom Paint Mixing
Collision repair professionals and do-it-yourselfers alike turn to O'Reilly Auto Parts AutoColor for unmatched quality and service. O'Reilly Auto Parts stocks industry-leading products such as 3M, Evercoat, Hutchins, Nason and Sata among others.
  • Over 500 O'Reilly AutoColor custom paint mixing locations across the US
  • A full line of automotive, custom, fleet and industrial paint
  • One of the nation's largest inventories of auto body equipment and supplies
Custom-Built Hydraulic Hoses
O'Reilly Auto Parts has over 1,300 locations that can custom-build hydraulic hoses. Whether you have a hay baler or a forklift, O'Reilly Auto Parts has hoses and fittings to help you complete the job.
  • 2 wire low-pressure, 4 wire high-pressure 1/4"- 3/4" and in several locations up to 1-1/4"
  • A full line of Gates fittings, hose and equipment to make or repair your own hoses
  • Hydraulic fluids in 1, 5 and 55-gallon quantities
  • Non-conductive hose and fluid available for specialty applications
Discussion Starter #12
I went to my local store and they are a no go. The guy said your more likely to see O'Reilly stores that mix paint more up north from us.
Seems easy enough to order some on line and have it shipped.
1 - 12 of 12 Posts
