1 - 2 of 2 Posts
I believe it is called a sprung trunk lid? My trunk is aligned (side to side, top to bottom), but the right side by the hinge is up higher. How do you correct this? Thanks in advance.
67 Mustang Coupe
to make your trunk lid sit lower at the hinge end you have 2 bolts securing trunk lid to hinge,insert a shim or washers between the bolt towards the rear of the car and the lid. this will lower it when closed. wes
1 - 2 of 2 Posts
