One more question guys...also with my stang' i've noticed he's starting to squeak in the rear axle area..LIke when i first take off or drive him real slow..it's a high pitch squeak...is this something major...do i need to take a loan out to fix him? or do i have to get a new rearend? Now,,,i"m a women here and not all clear on mechanic jargan...but any help is most thankful..shannon
HIgh pitched squeak, hmmmmm.
Does it do it when you go over a bump, or more on acceleration and deceleration? What about when you go around corners? Does it do it in reverse as well as drive?
More than likely, it isn't the rearend if its a squeak. Rearends make more of a groaning type of noise when they start to go south. What condition are the brakes in, does it do it while braking?
Get back to us soon.
Dave
Watch my progress at:
http://members.home.net/dciab/index.html
http://members.home.net/dciab/pics/67mustg.gif
o.k it does when it goes over bumps..but when i step up the gas it goes away..It also sounds like a rattling in the back right wheel.. it's getting bad and embarrsing...it doesn't stop when i tap the brakes...happens only when driving very slow about 20mph...i'm dumbfounded...
Discussion Starter · #4 ·
Could be one of the following;
U Joint
Wheel Bearing
Brakes
none will require a loan to repair!
Bob White (672nv)
Could be the bushings in the rear leaf springs, or possibly the
shock mount bushings. I think the leaf springs also have
anti-squeak pads between the leafs.
Later,
'66 289 2bbl. Sauterne Gold Connvertible
Shaummy
