Ok, I know a lot of people have installed a stainless overflow tank in their ride. I received mine yesterday (the 15"), and I just came back in from looking at my car.
From the pictures I have seen on VMF, most people have used a little spacer and mounted the overflow tank. The A/C condensor hose (I don't know if that's the proper name) is in the way, so I can't mount it this way. I do have a fan shroud, so I think I could mount it on the outside of the fan shroud, because that would give me enough space. Please see the picture below.
Any thoughts from anyone else w/ A/C who has installed the overflow tank? Pictures?
Thanks!
http://www.theneals.net/mustang/overflow-install-help.jpg
joe
I was able to mount my stainless tank on the shroud brackets (your option 2). Worked out fine, cleared the A/C lines and gave me more room to remove the cap. But I had to flatten out the 90 degree brackets that came in the kit to use them as a sort of extension.
Joe
I mounted mine further over across the VR on the Radiator support. I used fan shroud bracktes to mount it away from the wall
i did the option #2 , works fine
i think i used flattened brackets
p.s. you can use more antifreeze keep topping off the radiator after cool down, i think i used an extra quart and a half plus of antifreeze, you can fill to the top of the radiator with an over flow tank installed.
