I have a '67 with a 289 and Tri-Y headers. I had to change my starter and cable last year (not due to heat). I bought a replacement cable from Napa and it was much longer than the cable that came on the car. I was a little worried until I ran the cable...It now runs along the pan rail forward, out of the way of the headers and then out to the solenoid behind the alternator. I covered the cable in a heat reflective sheath from a local hotrod shop. It cost about $15. The routing of the wire looks good and doesn't go close to the header.
You might want to try an alternate routing before you let them cut up your car.
Glenn
Glenn
