Hello VMF,
I need help wiring this starter. I have a relay like this one mounted on fender apron. I assume that the body needs good grounding. Is that correct?
I thin I wire it like the Lower diagram in the attached image. Is that correct?
My starter has 2 lugs and a spade connector. I'm not sure which wires from the remote relay goes to which attachment on the starter.
Note: This is on an EFI 5.0HO.
Thank you,,
Sorry for the blurry starter pic, and for the order of images. I need to learn how to insert them within the text body.
Thank you,,
