So since I bought this Mach attempting to start would hesitate with a lazy "chug-chug" turning sound, then catch and start. Yesterday I plugged a tire pump into the cigar lighter and pumped up all my tires. Then, I tried to start the car and it would chug/turn VERY slow, lazily, then just went to a click when turning the ignition. I jumped it and it started RIGHT up so quickly w/ no issues. I drove it for 10 mins. then turned it off and it's right back to the lazy start to NOTHING again. All the lights, radio, etc. work just fine. Is it the alternator?
most likely its just an old or weak battery.
get it running put a volt meter on the bat and if you dont have 14 volts replace the alt and bat and while your in there the belts and the volt regualtor as well
Brand new battery that was replaced when I first got the car as this was a problem when I first bought it.
how old is it.
check the voltage at the bat with the car running
The battery is 2 months old. I'm thinking when I was pumping up the tires, it was drawing power from the battery excessively, killing it--which would be an alternator issue?
