I plan to add a tilt column to the '67 but I'm not fond of the swing-away feature nor do I like the look of the aftermarket columns so here is my question.
What year did the column change from the simple look of the '67?
You don't have to use the swing away option. Just use the 67 tilt column and you can manually tilt to 6 positions with out the swing-away. and you don't have to hook up all the wiring and vaccuum components. Works fine ez to install if you have correct steering box and coupler gary
Check out the new custom steering columns. NPD has them in their catalog...
Discussion Starter · #4 ·
Thanks Gary, I hadn't thought of that. Unfortunately, I've not found a '67 column for a resonable price thus my question. Maybe I should re-phrase it like this - What year did they put the emergency flasher and ignition switch in the column?
