Been almost 7 since I took the steering wheel and column apart. I see the bearing under the collar, next would go a retainer that fits inside to bearing, then the spring. Next the steering wheel hub and steering wheel. It's a GT performance wheel. I found this clip in my parts bag from when I dismantled everything 7 years ago. Not sure where this would go or it might have been off something else? Not sure.
The clip is the turn signal cancelling cam from a factory wheel.
Probably wont work on the GT performance wheel, though not sure
This ^^^
It mounts to the underside of the steering wheel. The GT performance wheel/hub will most likely have the pin style
746591
cancel.
Discussion Starter #4 (Edited)
The GT wheel did come with 2 pins. I wasn’t sure what they were for. Definitely doesn’t look like I can use the factory cam. This is the only place they can go.
