Hello to all you mustang fanatics..I'm missing a part for my streering column.Theres a lower u-shaped collar or bracket that wraps around the streering column with two studs that go thru it and then thru a upper collar or bracket and then thur the dash and then bolts thru the brake pedal support.I'm missing the upper collar or bracket thats between the column and dash the service manual says the part # is 3676 can anyone help me out? I reallly need this part by the end of Aug
Thanks Jim
