On a 68 the rag joint is a separate item, it slips onto the splines of the short shaft from the steering box and is secured by a single bolt. The end of the steering shaft is "D" shaped and goes into the other end of the rag joint. It is also secured by a single bolt.
[color:blue]68 GT500</font color=blue>
[color:green]68 1/2 CJ Coupe</font color=green>
MCA# 18519
I want to say that you need the short shaft steering box from either a 67 with tilt wheel or a 68. Not sure if all 68's had the short shaft steering box. When I added the tilt wheel to my 67 I had to replace the steering box to the short shaft style. SHELBY is correct about the 68, I would add that the short shaft steering box along with rag joint is integral. Meaning that you must use this type of box if your column has a rag joint on it already OR has the D shaped end. Hope this helps.
You could also cut your long shaft down and mate it up to a needle bearing
U-joint. I did this myslef when I put a '68 column into my '67 with the long
shaft. The U-joint was about $70 from Flaming River.
Rich
'67 C-code 'vert (Dees67)
'69 GT Project car - For Sale
Milford, NH
