Exactly. That is the "no liability" method.When I do mine I was going to tig weld the universal joint to the shaft. Problem fixed..
Which U-joint did you go with? The Borgeson universal?When I did my Borgeson conversion I used a bearing from Mustang Steve to support and hold the end of the steering column. I also used a u joint instead of the supplied rag joint after reading about failures like this. Works great for me so far.
Steering Column Shaft Lower Bearing Kit (3/4" Diameter Shafts) - Mustang Steve
Fits 3/4″ diameter shaft (most shafts without a rag joint) Fits 64-1/2 to 73 Ford Mustang, Falcon, Ranchero, Comet, Fairlane, Maverick and more. Fits any car with 2-1/8″ inside diameter steering column tube and 3/4″ diameter steering shaft. If you are installing a rack & pinion or Borgeson power...mustangsteve.com
It's not a new product. Borgeson has been selling these for at least 20 years now. Also, Ford first introduced modern Saginaw integral power steering on full-sized 1965 Fords. It's been rumored that a new CEO came from GM and that's why Mustang got it in 1971. But Ford was already using integral steering on bigger cars and trucks. Designing steering systems where the steering wheel can't pull out without warning goes back to the invention of steering.With any new product there are bound to be failures. Much like the o rings on the Challenger booster rockets that NASA had been warned might fail under certain conditions. Only in this case on a much smaller scale.
I guess when it warms up and I weld the o2 bung in my 67 I'll check the ones on mine.
Nothing wrong with that as long as you did'nt forget or if you loaned it out and the borrower did'nt forget.It's not a new product. Borgeson has been selling these for at least 20 years now. Also, Ford first introduced modern Saginaw integral power steering on full-sized 1965 Fords. It's been rumored that a new CEO came from GM and that's why Mustang got it in 1971. But Ford was already using integral steering on bigger cars and trucks. Designing steering systems where the steering wheel can't pull out without warning goes back to the invention of steering.
I used to have a 1978 Honda Civic that had a nut on the steering wheel that wouldn't stay tight. It would loosen rather quickly. All I had to do was finger tighten it every few minutes while driving.
http://www.borgeson.com/Images/09Catalog.pdf
Correct. '65/'66 are a full shaft, integrated into the steering box.To confirm.... my '66 with manual steering would not have a rag joint, correct? Car has been in paint forever and I can't remember.
I had a wheel cylinder fail on a 1965 ranchero in 1999 I was driving in town coming up to a stop light. My light was red. The crossing traffic was in full flow. I had to whip the car through the gas station parking lot and run it up on a really high curb to stop. Bent the heck out of the passenger side lower control arm. But I managed not to hit anybody else.Ironically I was on the way to my alignment shop when my steering felt looser than normal. In checking I had one bolt come out of the factory rag joint. The other bolt held as well as the two pins. Of course not as bad as the OP but still disconcerting.
As an aside, on a different car I had driven all over town, stopping at several red lights and lastly pulled-up to a store's front doors. From there on my way home I lost my brakes with a single master cylinder and coasted to a stop out on a country road. Never drove it again until I replaced it with a dual master cylinder. Just a thought.
I think these count as one of my nine lives, not two. But then there was this other situation..........
I don't know the part number but it was made by Borgeson and I bought it at Summit Racing.Which U-joint did you go with? The Borgeson universal?
I asked Borgeson a while ago about a u-joint to replace the rag joint I got with the kit. I was/am having a lot of rag joint flex but I'm going to try Mustang Steve's lower shaft bearing first. I didn't go with the u-joint immediately because apparently you'll feel a lot of road vibrations in the steering wheel.I don't know the part number but it was made by Borgeson and I bought it at Summit Racing.
