Hi all,
Have a rather complex situation going on. First I’ll start with the backstory. I took the car in for an alignment to a local shop that has a good rep among classic car owners. When I picked it up after the alignment tech said he pulled it into specs but wasn’t happy with it. Said the car was sloppy at higher speed and also informed me that he couldn’t set the right front camber where it needed to be because it was out of travel to be shimmed. He thinks the car might’ve been in an accident years ago and it might be bent up in the front right…. He said he did what he could and adjusted caster in a way to counteract the lack of camber on the right.
ok so at this point I head out and first the steering wheel is off center to the right, and then I notice that the car is super darty on the freeway. So darty that I was on edge to drive it. It had not been like this before the alignment. I decided to go to a friends who is into mustangs and he advised we change the power steering cylinder.
alright so we change that and it fixed the darty feeling on the freeway. Steering wheel still off center to the right.. that evening a friend and I take the car out to dinner and I notice the car still tracks straight but now the wheel is left of center… I’m really confused so when we get back I decided to drive the same route alone and sure enough the wheel is right of center again. It never used to be like this and I’m just trying to get it right since I’m a perfectionist. I’ll post a picture of before and after alignment specs from the shop.
few things to note
-Car has factory power steering
-Steering box is tightened so there’s no play but not so tight that it’s binding.
- track down the road doesn’t change only steering wheel position
So? What do you all think? I know that toe in should tighten the steering. Is that the thing that I need to change?
few things to note
