Guys I'm completely lost...My car has all new wiring harness all new courtesy lights and switches and bulbs... Including all new dash switches. I have wired multiple cars and I have never had this much problem. I've installed a new factory wiring harness...What has me stumped is I can run a jumper from the red and black wire on the headlight switch to the blue and black courtesy light wires and everything will come on and work as it should, but if I turn the switch to turn the courtesy lights on, nothing happens. I can open the doors and nothing happens. I know the grounds are working because the lights wouldn't come on with a jumper wire if they wasn't grounded. Even the glove box switch and GT Door courtesy lights are new and it will not work. I've put three new headlight switches which all work as they should just not the courtesy lights...I've also put in two sets of new door switches still nothing. Why would they work with a jumper switch but not any other way.....Ive cleaned all the connections on the harness and made sure they connected to the headlight switch ...I've put the jumper on the tops of the wires where they go through the top of the pigtail and I've run them into the connectors on the bottom of the pigtail and all lights come on.....Just stumped...
