I tried using a pressure gauge with the TV pressure port and that got me in the ball park but I've been fine tuning the TV adjustment by the "adjust and drive" method (which several of you said I would end up doing....). I have it now where the 1-2 and 2-3 shifts are not very harsh, but are not too soft. Before the thing would spin to nearly 3K rpm before the shift. Now it's in the low 2K range and feels pretty natural. The downshifts were also hellaciously harsh. Now the downshifts are noticible when slowing down (I can actually feel it slow the car down when the 2-1 downshift occurs), but the thing that is bugging me is the 3-4 upshift. If I keep my foot in the gas a good bit, the 3-4 shift is firm but not too firm. If I shift manually, the 3-4 shift is firm but not too firm. But if I take off slowly (like in normal around town traffic) the 3-4 shift seems like it occurs a little higher than it should, and is very harsh. I have a 2400 RPM stall converter. Would that cause the harsh 3-4 shift when accellerating normally? I've got a B&M Transpak to put in the tranny, but I know the shifts will be firmer and I dont' want the 3-4 shift to be so firm it breaks something (I've been told by several people the OD parts are the weakest link in the AOD). When the 3-4 shift happens now when I accelerate normally I hear what almost sounds like a clunk, and I'm pretty sure it would chirp the tires if it were a little harsher (like after the shift kit is installed...). If that isn't a problem I'll just drive it and enjoy the firmness, but I'd rather not break anything. For the past couple of days I've been upshifting manually so I get the normal 3-4 upshift. What do you guys think? Thanks /forums/images/icons/smile.gif
Shane
Shane
