Now that's a real man talk'in 4 ya!Go big or go home!
A "One size fits all, scenario!"
Common sense? Outa the question! 🤔
Yep! I use common sense while balancing the checkbook and on retirement strategies. Not on the Mustang.Now that's a real man talk'in 4 ya!
Communication is a a two way street. There are some very smart people here. If they are clueless as to what one is trying to convey, then maybe it is the one conveying the message that could take an introspective look.BUT YOU GUYS ARE CLUELESS AS TO WHAT I'M TRYING TO GET ACROSS TO U!
When EGO enters the scenario , COMMON SENSE goes out the window. You can "preach common sense" until the cows come home but you will never convert the heathens that LIVE off of power and speed. It been this way since the time of Roman chariots. "You" will not change it , sorry.Sure. Roger that 👍
Exactly. Just because it makes that power, doesn’t mean I have to use it when I go to the grocery store. But it sure is fun on saturdays. On weekdays, it would drive around just like any other car, because it was a good combo. There were no race car manners, but when it would go to the track, it did juuuuuust fine there too, and was a ton of fun.My Daily driver is BORING and gets 22 MPG. My GT350 at the drag strip "might" get 1 MPG but I have a HELL of allot more fun doing it. Do I need a 700 HP "sunny day'' street car ? NO , but my EGO says YES. I have worked 50+ years to get what I have and do what I do. I plan on enjoying to the fullest before I CAN'T. Others can penny pinch all they want , I'm spending MY dollars , not leaving them to someone else.
Yes, I can see your point!Exactly. Just because it makes that power, doesn’t mean I have to use it when I go to the grocery store. But it sure is fun on saturdays. On weekdays, it would drive around just like any other car, because it was a good combo. There were no race car manners, but when it would go to the track, it did juuuuuust fine there too, and was a ton of fun.
I’m going with 5/8 cam. 😜We got it. We ALL got it. Now can we get back to all the benefits of upgrading SBF heads and running 3/4 race cams with hydraulic lifters and shallow compression deep dished steel pistons.
I've got a 2002 F150 7700 to tow the Mustang. A 5/8ths ton truck. Perfect!I’m going with 5/8 cam. 😜
Sure, you can always upgrade to an 11/16 grind later.I’m going with 5/8 cam. 😜
I don't know about that? The 13/16 cam might give up a bit on the low end but makes up for it on the top end with the right gearing.Sure, you can always upgrade to an 11/16 grind later.
I understand that U lucky guys, with deep pockets and bottomless bank accounts, I completely understand U don't appreciate having to settle for less than the best.We got it. We ALL got it. Now can we get back to all the benefits of upgrading SBF heads and running 3/4 race cams with hydraulic lifters and shallow compression deep dished steel pistons.
What makes you think people didn’t know that? What makes you think spending less money on aftermarket heads, instead of pumping into stock heads is “thrifty?” Why do you value your opinion so high, and trash everyone else’s?I understand that U lucky guys, with deep pockets and bottomless bank accounts, I completely understand U don't appreciate having to settle for less than the best.
But for the ones that have been there and the ones that still are, at least they know there are some thrifty options available to them.
U R Welcome! 😏
Do you have a website for the bottomless back account? I'm all over that! My car was purchased and built 100% on working overtime and not a penny from the family budget. You fly in from nowhere and try to tell us all how it should be knowing nothing of the path we took.I understand that U lucky guys, with deep pockets and bottomless bank accounts, I completely understand U don't appreciate having to settle for less than the best.
U R Welcome! 😏
I got my cam from a European grinder... it's a 22mm.Sure, you can always upgrade to an 11/16 grind later.
Aways trying up me by a mm Bart!I got my cam from a European grinder... it's a 22mm.
