Howdy,
I upgraded my alternator to handle all the toys I have. Just use a relay that you buy with the fan, and check for power across the battery when the fan is on. Make sure you are getting at least 13.0 out of it, and you will have no problem. If not, an upgrade would be in order.
Also, don't use those straps that go through the radiator. They will eventually vibrate so much they will wear a hole in the radiator (it happened to me a month ago). SPAL makes a 16 inch that low-profile and a regular profile that should fit just about anything.
Good luck with it,
wsgts
