Either the distributor is a tooth off or the mark is at TDC, which is 0 degrees and the ignition needs to happen before that.
Basically the timing mark on the balancer is at the 12:00 position and if i move it to the mark on the cover it dies but where I have it now runs the best but has a slight missI don't fully understand the question. Some punctuation might help clarify.
Well chances are strong your timing marks are off then. You need to find TDC and verify.Basically the timing mark on the balancer is at the 12:00 position and if i move it to the mark on the cover it dies but where I have it now runs the best but has a slight miss
Otherwise tell us exactly how you did this. You may have done it perfectly, but then we are back to testing TDC with the tool...I put the distributor in correctly
C,If your vacuum advance is connected to ported vacuum, nothing will change when disconnecting it unless your idle is set too high.
If engine gets worse and dies as you adjust the 10 degree mark (white line) towards the timing pointer, then the harmonic balancer must be wrong or has deteriorated and slipped. I don't think that any small block ford timing pointer is at 12 o'clock, but it sounds like this is where your engine wants to run, so it has to be close.
The 9 washers behind the timing cover/water pump bolt tells us that there may be a mismatch of parts also.
The distributor being "off a tooth" or wires not in the "correct" location on the cap do not affect timing, unless the distributor housing has not been turned to compensate and then the engine will run like crap.Either the distributor is a tooth off or the mark is at TDC, which is 0 degrees and the ignition needs to happen before that.
Another way I was taught to do this was in an engine overhaul class last year. You can stick a long screwdriver into the spark plug hole to verify TDC.You are getting good advice. But to know what is causing the issue, you need to verify TDC of #1 cylinder with a spark plug thread piston stop. About $10 online if you shop around, or make your own from an old spark plug and a bolt. This tool will show exactly where TDC is, and if your damper ring has slipped, or your distributor is off a tooth, or the plug wires are off a terminal, or using the wrong timing pointer or damper, etc.
Otherwise tell us exactly how you did this. You may have done it perfectly, but then we are back to testing TDC with the tool...I suggest you use the tool, or an equivalent method.
👍🏻The distributor being "off a tooth" or wires not in the "correct" location on the cap do not affect timing, unless the distributor housing has not been turned to compensate and then the engine will run like crap.
No, you can't. You can tell when the piston is in the VICINITY of TDC, but since the crankshaft rotates in a circle the piston "dwells" near TDC over a number of degrees which you really can't perceive with a screwdriver to accurately mark a timing scale.Another way I was taught to do this was in an engine overhaul class last year. You can stick a long screwdriver into the spark plug hole to verify TDC.
The piston stop seems better than a screwdriver. Thanks for the explanation!No, you can't. You can tell when the piston is in the VICINITY of TDC, but since the crankshaft rotates in a circle the piston "dwells" near TDC over a number of degrees which you really can't perceive with a screwdriver to accurately mark a timing scale.
From the point when the crank throw is at 90* upward, the piston speed slows considerably to zero at exactly TDC. Depending on the stroke and the length of the connecting rod, the piston may be near stopped from a number of degrees before and after exact TDC. This is why, when you use a "piston stop" to determine TDC you rotate the engine back and forward against the stop and select the point exactly in between.
