1 - 9 of 9 Posts
I just acquired two Cleveland 2V heads and a Street Boss 302 intake. I have a 289 torn down right now in the shop. Could I use the 289 as a base, or maybe use the rods and block with a 302 Crank? Or should I just try and find a 302 short block? Article I have says to use Boss 302 pistons with 289 Rods. If I go 302 block and crank, can I go with a roller block rather than flat tappet?
One word: stroker!
That is what I am going to do with the original 289 block from my 66. It is going to be fun! I'm pretty sure those Cleveland heads won't fit a SBF since the Clevelands are considered Big Blocks. Try to find a nice set of GT40 heads off an Explorer.
FWI...clevelands are NOT big blocks. they have the same bore spacing and mounting patterns as a 289/302/351W. where do you think the BOSS 302 heads came from in the first place ? please do not continue the false notion of 351C= BB. not flaming ya just trying to get yer info corrected.
Thats the ticket!
With those open chamber 2V Cleveland heads you'll have pretty low compression, that's why the Aussie Cleveland 2V heads were so popular for a while... Small combustion chambers, close to the same size as the Boss 302 chambers.
Boss 302 used the same length rods as a 289.
IF you are using BOSS 302 type pistons then you really should go with the 289 rod and 302 crank. and yes a 5.0 roller block will work just fine. look for the "siamese" bore block from a 90-93. and they like lotsa lift and duration.
Remember when choosing a cam that Cleveland Heads use 1.73-1 ratio rockers, not 1.6-1 like 289/302/351w. Also you may want to look into the coolant passage locations on the later blocks, I believe, but don't quote me, that the later blocks had the coolant passages on the blocks moved to match the location of 351w heads. Also I have an older ford motorsports catalog which list what modifications are required to put 351c (non Boss 302) heads onto a windsor block. I can scan it for you if required. That should make for an interesting combo and won't be a "ME TO" set up that you always run into on cruise night.
Dan
I would appreciate the scan. Thanks so much. If you will, attach the scan and email me at [email protected]
You can use the 289 block and rods. Adding 302 crank (I prefer 28 unbalance) and BOSS type pistons will give you Street boss short block. However, I don't know where you can get the pistons, I have heard that TRW/Speedpro L2324F is probably discontinued.
However, roller cams rock compared to flat tappet cams, if the 289 block is in good condition, I would sell that and buy a roller block.
1 - 9 of 9 Posts
