Installing a SOT front end on my 1969 mustang (bought front and rear kit 3 link package), all the parts are great, wonderful quality. One thing is that if you have a Unisteer rack and pinion kit the camber kit will not work. The issue is with the rear LCA bolt access. It seems you could drop the rack and then plasma cut the access holes bigger in the rack bracket....seems like a lot of work. Also, the eccentric washer thing is captured when you install the unisteer, so when you take out the stock LCA, you have to fish out the eccentric washer, which in my case slipped down and is pinned between the rack bracket and the frame, 30-45 minutes or so of fiddling with it and you can get it lined up again...yay! So, if you are in my situation, when removing the LCA bolt put some kind of ream (bolt or whatever) so it does not get lost in the abyss and just use the stock adjusters. I would not have bought the camber kit if I knew it would not work with the unisteer. For the cost I paid for the kit the extra camber kit is small, but would be nice if this info was provided up front when ordering. Thinking that down the line I will drop the rack and enlarge the access holes....but c'mon probably never gonna happen.
