The passenger side spindle on my 65 FB was removed so that I could replace my UCA and LCA. I reattached the spindle to the ball joint studs and torqued the castle nuts to spec. I can't move (turn) the spindle at all. Do I need to use a puller and pop the ball joints loose and attempt to retourque the nuts? I followed the same procedure on the driver's side and it moved without too mush effort. Any Suggestions? TIA
