So I replaced my water pump a while back, and I noticed today that one of my fan bolts has backed itself out a little bit. This strikes me as being pretty dangerous. IIRC, the fan bolts slide through the fan, through the spacer, through the pulley, and then thread through the pater pump. It seems to me that there should be a nut or something on the back side to hold it all together. Maybe there is and I just don't remember putting them on? Maybe there are supposed to be nuts, but they weren't there when I acquired the car? If there are not supposed to be nuts back there, what keeps the bolts from backing themselves out?
So that's my first question. My second question is what is the trick for removing the fan (bolts) w/o removing the radiator? I've got no more than one inch clearance between the fan and the rad, which obviously means I can't back the bolts all the way out. So either my bolts are too long, or there's a trick I don't know.
Thanks!
Thanks!
