Stupid question... what's a stall converter?
Not stupid...at very worst, ignorant...we were all there once *G* Looks like you learned alot already.
I'm going to be driving this car on the street a lot... so I guess I should take that thing out. Is there such a thing as a stall converter that I can turn on and off?
IMO, leave the converter in there, especially if the engine is a 4V (large port) Cleveland. You should have a 3.50-up rear gear for this combo, which will be fine for combination street/track driving with a 10" converter (likely what you will have). Be sure the app has an auxilliary external trans fluid cooler.
I've run 4.8K stall 8" converters on the street and, practically speaking, they're as normal to drive as stock converters, except you can leave the stoplight in high gear without any problems..*G* The
race car currently has a converter similar to yours in it and is emminently driveable (once it's off the trailer, I drive it everywhere, even to get a hot dog and soda)...only time you would notice the higher stall is when briskly accelerating or power-braking the car (known as stalling the converter) on the starting line. I usually leave the line at about 2800 to leave a little flash room (converter flashes to 3200)...
Hope that helps!
