Hi Folks,
I would like to install sub frame connectors on my 69 Mach 1 but I already have under ride traction bars on it. Will there be any interference by adding the subs (i.e. will the rear mount of the sub hit the front mount of the traction bars)?
Thanks all,
Paul
I don't know if the connectors will interfear with the underrides or not, but, just installed connectors on my '70 Mustang. I used the TCP connectors, and the rear of these connectors go back to about 1/2" into the access hole in the rear frame rail for the front spring eye bolt. I am afraid that they will interfear, but, good luck. Hope this helps.
question is why? you running 500HP?if your running stock or slightly modded, you dont need to worry about twist.
Administrator
I just ordered the under rider bars from Mustang Plus.
Mustang plus was also supposed to send me the complete TCP supframe kit, but they never contacted me....
Ugh!
