So, I have the old 1965 Fastback stripped of its "falling apart" suspension. Have a bare chassis outside and inside.
On the floor pan, I have replaced a 3" (front to back) x 8" (side to tunnel) piece on the driver side and a 3" x 4" on the passenger side. The floor and frame are solid with key dimensions measuring in specification ( I used this dwg found on the net, disregard the RED, as is not my dims.). Next step is to clean up the bottom, protect and paint. I'll have the car mounted on the front bumper frame mounts and rear Leaf Spring mounts and balanced on the rotisserie. Question is...
Am I just asking for trouble? Should I wait another 3 months until my suspension arrives and is installed?
Any opinions are well appreciated! TIA
- Can I install sub-frame connectors while the uni-body is on the rotisserie rotated 90 degrees?
- Can I weld in front Torque Boxes while the uni-body is on the rotisserie rotated 90 degrees?
