Well I put in my subframe connectors and they do work wonders. Just backing in and out of my driveway I do not have anymore squeaks and creaks. I just test drove it around the block a few times and it is a BIG improvment and I didn't even get them welded in yet. (bolt-in type)
But, the directions make it sound easy. Remove front eyebolt and replace with the bolt provided thru the connector and frame. What they do not mention is when you remove the front eye bolt. The spring moves up toward the body. You have to remove the shock mounting plate to relieve the pressure on the spring. But they do work!! /forums/images/icons/smile.gif
