Got the car home yesterday. After I cleaned all the junk out of the interior I noticed that there is some surface rust on the driver's floor and some other places. Nothing major, I could just sand it off and paint, but I want to make sure that I do this right.
What if any experience have any of you had with the above choices, or do you have another method? I read the article in the latest issue of one of the Mustang magazines, can't remember which one, that used the POR floor repair kit. I don't have any holes, so i am just looking for what will work best to prevent future problems.
The car has apparently been sitting outside at the place I bought it from for about 11 years, I don'tknow how long without the doors, so I am amazed that the car is in such good shape.
This question comes up frequently and everyone seems to have their favorite, so for what it is worth I'll pass on my limited "wisdom":
POR-15. - produces a hard surface; can't handle brake fluid;. I could never get a smooth surface. VERY TOXIC, have lots of fresh air.
ZERO RUST- easy to use; not very toxic; doesn't produce a "rock -hard" surface. Takes many thin coats to seal off rust.
Hirsch Miracle Paint - A lot like POR-15; very toxic and gives rock-hard finish. Holds up to brake fluid better than POR-15
Chassis Saver - Similar to POR-15; doesn't seem as toxic; holds up to brake fluid. Cheapest of all of the above.
Again, this is my experience others may have had other results.
Hope some of this may help.
Tom
If it's the textured grain on the door I wouldn't sand, use POR15, or Eastwood's Rust Encapsulator. All three will make the texture disappear. I would hit the rust patch with metal prep. The stuff I use is PPG Metal Prep and is similar to Eastwood's Oxysolve. It's acidic and eats the rust off leaving the good steel behind - if you keep at it and don't let it dry out before rinsing. I found on the exterior of my fender aprons and shock towers I had to treat it several times to reduce the rust to minimal.
I plan on using metal prep on my '65 I6 doors next.
Dean T
I would not sand, but remove the rust with a wire wheel so as not to remove the graining. Then treat with an acid wash (MetalP Prep etc)to "kill" the small rust remaining. Both Corroless/Rust Encapsulator and POR-15 are thick, and would fill the grain, so I'd recommend thinning Rust Encapsulator and using a light coat of that prior to topcoating. Don't use the POR as you need to use a topcoat primer to get other paints to adhere, and the 3 coats of paint will definitely fill the grain. Good luck. DIckson
