Swapping a 67 Dual MC into my 66
748 6
I'm purchasing a rebuilt 67 Dual M/C and wanted to replace my single reservoir master cylinder in my 66 with it. I'm going to have bend lines myself.
Anything I need to know before I get into this? Is there somewhere I can get a plan for bending the lines or is it something I can figure out without too much hassle?
Thanks.
Hope this works...
There are alot more things to do and worry about. Your old master cylinder uses a hydraulic pressure switch for brake lights. To avoid having a pressure switch for each chamber of dual chamber master cylinders Ford starting in 1967 for Mustangs used a mechanical switch located on the brake pedal mechanism. For the two conversions I've done, I plumbed the old pressure switch into the front brake circuit.
I think you want to consider using a distribution and proportioning valve and it's warning light system for brake failure.
I believe all brake system tubing flares should be double flares. Do you have the tool for this?
Try doing a VMF search for old messages on this subject for fuller explanations.
Hope this helps.
Russ
I have what I thought was a mechanical switch connected to the upper arm of my brake pedal. Also, can I use the proportioning valve from a 67 also, I'm guessing I can.
How much time do you think this will take? I have a line bending tool but I'm not sure about the double-flared end deal.
thanks for the info.
Sorry, no answer but ? What happens if I just plumb dual MC (it is from Baer kit, a friend did not use it in his late model) into existing brake lines without doing anything else. I have 65 with disc brakes and single reservoir disc brake MC. It has a proportioning valve in the rear brake line. Would this be enough or is it mandatory to install a adjustable prop.valve?
Door handle first
The second time around it was much faster, mostly reduced thinking, reading, checking other cars, and thinking time.
Is this a manual brake master cylinder? Have you searched prior VMF messages for this conversion?
Russ
Discussion Starter · #6 ·
I am assuming you have drum brakes.
You should get a distribution block from a dual system drum brake car, 67 or 68 works well. Don't use a proportioning valve or a combination valve from a disk brake car. With the dual system distribution block, you will get a differential pressure valve that supplies a ground electrical connection if there is a failure in either system, front or rear. I used a differential pressure valve so I could wire up a brake defect warning light and alarm. If you don't want the switch, you could skip the differential pressure valve and plumb the front two lines through a tee to the rear MC port and the rear line directly to the front MC port. Some people have used the original distribution block for the front lines with a plug for the former rear line hole. They then plumb the rear line to the front port on the mc.
I used a a MC from a 67 Mustang. DO NOT USE A REBUILT MC. One, they will leak in a short time. Two, they come with the 1/2 " shorter 67 pushrod already inserted, so you will have to break an internal clip by pulling on the rod. You need to use the original pushrod from your 65-66. Buy a new MC and the pushrod is supplied, but not inserted, so you just toss it. By the way, the new Bendix MC was $58 at Advance Auto and $90 at Trax Auto. Same part number; shop around.
The rear line on a 65 Mustang ends at the distribution block with a 3/16 flare fitting. The distribution block on a 67 used a 5/16. Check ahead of time so you don't have to wait a day to get an adapter.
Don't believe the parts guy when he tells you they don't make such an adapter when what he really means is he doesn't stock one.
Discussion Starter · #7 ·
Yes, it is a manual MC. Searching VMF was what gave me the idea about using a 67 MC. I'm not very knowledgeable about proportioning valves and such but was hoping my manual and a friend who owns the brake line bender will be able to get me through that part.
