Keeping my original 66 front sway bar and just received new bushings from NPD. Figured this would be easy but I don't see how to get these on. Seems no way the bushings will fit over the ends of the bar - the bushing are not split. I did search, no answer - feel like I must be the dope. Any thoughts? Thanks
Hi,
I had the same problem with it. no lubricant and no heat didn't help. I've asked ndp and they have told me to cut it open.
peter
IF your doing a restoration I would not cut them. IF not a restoration the cuts will slightly effect how they work but you will likely not notice.
Might be the reproduction would nto eb the first time that one didn't work/fit as designed
I bought a set the other day for my 71 Ranchero. They were obligatory parts house bushings - they were already split right out of the box.
If you cut them - they should preform fine if everything is nice and tight. If you're doing a concourse restoration, then you shouldn't be installing poly bushings, and the rubber ones with some lubrication should slide on.
Since you're in the concours forum we'll assume you don't want to cut them. If you soak them in very hot water for 5 or 10 minutes they'll soften up. Blot the bushings dry, spray the interior of the bushing and the end of the sway bar liberally with silicone, and then they'll go.
