I need to replace the headlight switch on my 1966. Any tips? I have had the gauge cluster out to replace lamps and the ignition switch, but cannot figure out how the headlight switch is removed. Thanks
Its not hard to do. Under the dash, on the switch itself, you'll see a button, its not very bit. Push the button in and it will release the knob, which you pull stright out of the dash. After that its pretty stright foreward: unscrew the beezle, then a nut behind it. Slide out the switch, unplug the wiring, then reinstall the new one. Hope that helps.
