Hello all!
I hope you are all in good health and staying safe during these uncertain times.
I've got some questions about my Borg Warner T-10 four-speed transmission. It is currently in the car with the shift mechanism installed, but without the shifter attached. My questions are as follows:
1. Do I need to remove the shifting mechanism to replace the U-shaped bracket and pin that the shifter bolts to or can I do it in the car?
2. When I go to install the shifter itself, the bolt closest to the seat does not tighten down all the way-- there is still a gap between the shifter and the bracket, but the bolt feels tight and I don't wanna crank on it for fear of damaging something. Any idea why this might be? Can I just use another shorter bolt, or is the special threadless-at-the-top bolt important? Should/can I add washers under the existing bolt?
3. The farthest I've gotten when installing the shifter is completely installed except for the bolt that won't tighten down all the way (the springs, trunnions, everything included in the 4 speed shifter rebuild kit from NPD). The detent is still on the 3rd/4th gear side-- to get to first, I have to go left and up. Is that the way it is supposed to be? I feel like the detent should have the default shifter position in the 1st/2nd gear lineup?If that's the way it's supposed to be, why is my detent wrong? I've installed all the parts for a shifter rebuild.
4. Lastly, please confirm that the gear oil I ordered for the T-10 won't make it blow up
Seems like everybody has a different recommendation. Link to the oil I purchased HERE (Red Line MT-90 75W-90 GL-4 Manual Transmission and Transaxle Lubricant). I ordered two quarts.
I'm looking forward to hearing from you all! Thanks in advance, all input is appreciated.
Cheers, Alex
Cheers, Alex
